Air Filterization
champion rider
Finding myself just short of satisfied, I had to do some tuning action performance style things, so here goes.
Paper Filter --> Stock filter is excellent, but could be a limiting factor once tuning comes into play.
Racing Filter --> More Flow, only prevents Leafs and small mammals from entering airbox.
Filter Lid --> More Flow, adequate filtering, excessive noise.
For my purposes, I chose to measure performance with the amounts of liquid used, in this case 102 octane, on the same stretch, various conditions, alternating set ups at "random" to keep it fair. Repeatable.
Vs. base line (stock)
Paper Filter & Lid: 4.16 % reduction
Racing Filter only: 2.70 % reduction
Racing Filter & Lid: 5.41% reduction
Next step.
A long intake, such as the stock snorkel, should make more torque, and a short one, such as the filter lid, more top end ponies. Variable length is common on some forms of transportation.
Using K&N Airforce Foam & Dry Charger I created my own variable length intake with the use of some simple mechanics.
Result Vs. base line (stock)
8.33 % reduction
My conclusion: 14 bucks for 3% economy --> worth it.
Side effects: Reduced intake noise --> worth it.
Here are some pics of the material used:
I'm don't understand...
You did rode a test route for each variation and measured the fuel economy? Is that what happened?
And you used less fuel with the options compared to stock?
"Paper Filter & Lid" --- Isn't that the stock configuration?Or did you remove the snorkel for these tests?
Next step.
How did you make a variable length intake? Wouldn't that require a servo?
Yes, all versions were tested multiple times in test track type circumstances, setups were switched around at random after specific intervals just to get fair results. Various switching procedures were also followed, again the goal was really to achieve a fair result.
In all cases the the basic principle was simply not to physically alter the airbox with holes or snorkel mods or that sort of stuff.
I also had some other versions which I felt were garbage after 5 minutes so I didnt follow through with conclusive testing and discarded the idea.
Let me make a sketch of what I described as variable length.
So as you can see in the very rough sketch below, I achieved the desired results through the use of two different prefilter media and the same primary filter type.
For the snorkel (on the left side), the drycharger material allows the air to pass through "easily/rapidly" but is also sized so that it has a limited volume.
The foam used above the lid has a much higher volume and was sized so as to not flow as "easily/rapidly" as the drycharger.
Assuming the air takes the path of least resistance it would go like this:
1. Initially with little throttle --> the long way through the drycharged snorkel
2. After exceeding the snorkel volume limit with more throttle --> the short way through the foam.
