2023 Svartpilen rear splash guard mod?
OblivionLord
Florida
I have a friend with a 2023 Svartpilen and he likes the stock look with all of the stock components.
He does not want to do any mods at all because he truly likes the stock look. He is ok with 'some'
changes as long as they improve the efficiency such as thicker grips for comfort. That's the only
mod he has done because the stock grips were hurting his wrist.
Given all of this information, I am the one that does the maintenance on his bike and I'd like to know if someone
has conjured up a way to mod a split in the electrical wire going to the license plate from the front? This
wire goes from the front and routes to the back through the chain guard and splash guard. I can't
detach the electrical wire easily to detach the chain and splash guards. If the bike was designed with a split
connector near the rear spring then it would be very easy to detach to then completly take off the
The only other thing I can think of doing is convincing him to let go of the stock splash guard and replace it
with an aftermarket guard this way I can reroute the license plate light wire to go under the Pilon seat along
with a tail tidy. If he is ok with that then that solves everything. If he doesn't then its back to me having to
deal with both guards being stuck with the wire.
Thoughts?
