The Galfers look superb.ok, so what is a better choice
Brembo https://www.genialmotor.it/en/brake...MI2uvMi5m-lQMV9FJBAh2GTxrqEAAYASAAEgL2BPD_BwE
Or
Galfer https://www.genialmotor.it/en/galfe...e-320x5m-ktm-890-duke-r-2019-2020-282219.html
I am not skilled enough, but ... if I use for example Brembo M4.32, these calipers are same dimensions and same diameter of brake cylinders (pistons) as the original JJ. So they would brake "the same", no? Or? Where should the better braking come from??
If I will fit some M50, it will have bigger diameter of the cylinders, which means, that there will much longer lever movement on the master pump, no? But brake better, this is clear.
I was surprised, that 300=>320 discs will make just 6,7% difference of stopping power ... due to my mathematics :-D
I had the 990R as a loan bike for a day. I really liked it! A lot better brakes and suspension than the 801 and of course some added power (130hp vs 105hp). Too bad I really dislike the colors on the 990R. Orange rims will be a pain to keep clean.I found almost new calipers from SA1290R close to my home for 200€, so I went to buy them. They fit 1:1, Rottweiler performance used them on Duke 790 also.
Change was easy. I went just for a short ride. It went better with each braking, don ´t know, if the pads are fully settled, but it brakes better. Feeling on the lever is almost same, which is not a surprise.
Change the pads will probably be enough.
Anyway I am still thinking to get 890R or new 990R, but keep the 801, because I love, how easy the bike handles and how comfortable it is.
I also visited a dyno, but nobody is able to unlock/break in to the ECU. If that will happend, with the suspension and brakes now, I will have 801R :-D
