"Tweaked" 801 stock muffler
Tom
Germany
A couple of pics how the 801 stock muffler can be "tweaked" with a removable custom-made db-killer; it's still work in progress.
OK, you know what you're speaking about. ;)
Yes it was indeed a lot of work to fabricate the adapter ring to fit it that snug. It took me some hours; but finally it works fine.
An additional pic of the short db-killer; now with some screws to fix the pipe in the adapter.
After a first short test with the modified muffler I'm very satisfied; I will give it a try on my next daytrip.
Here some short videos:
With the stock db-killer:
Without any db-killer:
With the short custom db-killer:
On today's daytrip I tested the short db-killer; it's raspy and not too loud; it's perfect to me.
Today I noticed that the pipe of the db-killer suddenly stuck a couple of millimeters out of the muffler.
I checked it; wondered that it was quite difficult to remove the db-killer; and that's what I've found; definitely not what I've expected.
The melting temperature of aluminum starts at about 600°C; the exhaust gases are too hot.
The adapter-ring made from 20mm aluminum doesn't work.
Today I started fabricating a new adapter-ring; now made from 10mm steel.
Today I reassembled everything; to seal the db-killer I used some additional exhaust mounting paste; ready for the next daytrip.
Was it fairly straightforward to remove the stock baffle? You mentioned drilling around the metal plate... is there enough room for a dremel with a disc cutter? Thanks.
BTW, your engineering is very impressive 🙌🏻
Thank you!
I did it by drilling the sheet metal around the stock DB-killer; it's made from stainless steel, but not too thick; drilling worked fine, but I don't think it will work with a Dremel.
Afterwards I did some grinding and some filing to smoothen it out; I used a straight-grinder.
At all, with some proper tools it's not too difficult.
Tom,´´At all, with some proper tools it's not too difficult´ And obviously the skill to use them.
