2020 Svartpilen Custom Exhaust Build - Pics
2233Designs
Vancouver Island, BC, Canada.
Hey all,
There's been a few questions about how I went about building and installing the exhaust on my 2020 Svart.
I figured it would be easiest to post up some pics with details, then any specific questions I can answer after that.
1. This is the entire 2020 system, up to the slip on muffler. I didn't realise the header pipe actually has about 6" of secondary cat material that slips into the big resonator box. I thought I could cut the flange off the front side of the box to make my 'S' pipe off of. Unfortunately, this wasn't possible.
2. I needed to modify the header pipe, by cutting off the cat material at the header rear flange. I wanted to keep some back pressure, and slightly restrict the flow, so I just drilled a small 1" dia holesaw hole through the cat material.
3. After reinstalling the header pipe, I was then able to take my stainless mandrel 'J' bend, and cut 2 sections to the radius and length I needed to meet up to the muffler where I decided I wanted to mount it. (I had tack welded on the muffler bracket and mounted it on the footpeg mount before this, to ensure I knew where my 'S' pipe needed to mate up to).
4. Now that I had my new cat delete pipe all mocked up, it was time to weld it up. I am a terrible welder, but I wanted to do this all myself, so I could say I built it all myself.
5. I notched the 3" delete pipe flange to make sure it would fit over the 3" header flange and gasket, then reinstalled the 'S' pipe, then slipped the muffler back on. Job done. Still need to clean up my shitty welds, paint them up, and then put on some spring loops. I just wanted to squeeze out as many ride days as possible before the weather really goes to shit.
