seb_lawrence
Hello everyone,
I just bought a Svartpilen 401 at an auction in pretty miserable shape. Stolen, grafiti all over , missing many parts etc.
In trying to restore it , i purchased all the necessary items, minus the headlight as I can't find one.
The problem is - I can't start the bike.
Engine turns over, I can see that there is a spark from the plug as I tested it and it smells like gas when I open the plug , so spark and fuel are available.
Fuel pump makes noise and I can see gas in the filter and it smells like it when i take the spark plug out.
The odometer reads CAN HLU failure and ABS failure . First is understandable as there is no headlight , the second I believe is a connection issue.
I am not sure if they have any relation to not starting. When I press the button the starter moves the engine every time, but can't fire it up. Which tells me starter the relay works.
Am I missing anything here. Fuses, other electronics?
I tried to push/roll start it , but no success - it did make a little bit of noise and it made a low bang in the exhaust twice , but that's it.
Any words of wisdom are massively appreciated!
Thanks,
Seb
Thanks,
Seb
