Rear wheel spindle mixup
pudding
NE USA
So, since this thread went up about an undertorqued rear wheel nut, I wanted to make sure mine was correctly torqued. However, since I was in a hurry (and an idiotic noob!) I was checking the torque on the WRONG side of the bike, i.e. the left side which I guess is the spindle side. So I set my torque wrench for 90 N m and was alarmed at how many turns it took to torque it down to 90. Three or four complete turns maybe? But then I realized my mistake, and to compound that error I realized I don't even have the proper sized socket for the correct nut on the other side.
Sooooo, my questions are:
Did I damage something? (Though there is no apparent damage)
Should I loosen it? (But I don't know how much to do so)
Was planning on a long ride tomorrow, so would love some sage advice. Thoughts? Thanks, Hive Mind!
Completely agree with Ben Dover
17mm on both sides. (Preferably 6 sided)
Hold the bolt and torque the nut and dont lift the bike off the stand while youre doin it.
Probably wouldnt hurt to recheck you chain tension / wheel alignment while your at it.
You put the torque wrench on the "bolt/spindle" side instead of the "nut" side? And you turned the torque wrench to tighten things, turning the entire spindle while the nut remained stationary?
If the above is true, you are unlikely to have overtightened the nut, it's possibly still undertorqued! Turning the bolt/spindle side adds the friction all through the wheel on both sides in addition to the nut on the far side. I think it is highly unlikely anything is damaged.
Fun fact: on some (older) bikes, there are nuts on both ends of the spindle.
Thanks for all the replies! Sorry, I was away. . . before I received any replies I spoke to two separate dealerships who both told me that it wouldn't be a problem, so I've been riding on it all week and am thus far injury-free. Though I'll take your advice to retorque.
That's correct.
One caveat however is that the nut doesn't seem to be a 17mm like suggested above. My memory serves that the spindle side is 17mm. . . I have sockets up to 20mm, and nothing fit the nut. And since I left the bike at my friend's house in another state for the time being, I can't measure it. Would someone who has a 2020 SP401 be able to measure the nut so that I can order the correct size?
Thats an interesting point.
The axle is the same part, and yes the nut is a different part.
I am sure someone with a 2020 has done a chain adjustment.
