I <3 Svart
This is something that kind of confused me at first and I didn't see any threads addressing this specifically either on VitpilenForum or here so I figured I'd make one especially since Husky's included installation guide is kind of vague. This will be a guide for installing the first-party Husqvarna bar end mirrors on 2020 Vitpilen and Svartpilen 401 models. My goal is to make this guide so complete that you can refer to it exclusively without needing to refer to the Husky provided guide.
First thing's first; the OEM lollipop mirrors on these bikes suck. They vibrate like hell and are only useful for seeing if you accidentally got mustard on your elbows at lunch. They're ugly, they're dangerous, and frankly this is the one absolute must-have modification on any Svartpilen or Vitpilen from the first one that rolled off the production line to today in 2020. The Husky bar end mirrors are a massive improvement both practically and aesthetically. In my experience they do not vibrate and when properly installed and adjusted they allow a clear view of the road behind you. In a sane world they would be the factory mirrors that come on these bikes, but alas we live in this world where arbitrary, theoretical safety standards take precedence over observable, practical safety. To right this wrong we must turn to the aftermarket and specifically to bar end mirrors.
Tools/Parts Needed:
- 2 x Husqvarna Bar End Mirror (Part #21012940000)
- #3 Allen key
- #5 Allen key
- Cutting tool (maybe)
- 1-2 adjustable wrenches
Step 1) Removing the bar end weights
Insert a #5 Allen key into the end of the bar and rotate counter-clockwise until the bolt has been removed. On my bike the clutch side bar end weight was also held in place with adhesive in addition to the bolt, but this adhesive was easily broken by rocking the weight back and forth and did not interfere with installing the new mirror. I found no such adhesive on the throttle side, but your mileage may vary.
Step 2) Preparing the bar end mirrors
This is the part that kind of threw me off because Husqvarna included a whole bunch of washers, nuts and sleeves preinstalled on the mirrors that are not necessary for installation on 2020 401 models.
Remove these sleeves, washers, and nuts until you are left with nothing but the mirror stalk, mirror spacer, and a bare bar end bolt. Most of this crap will already be on the bolt straight out of the package and you need literally none of it for installation. Apparently these parts are for installation inside the hollow bars of the 701s (thanks nampus). Either way this part is completely different from the included Husky installation guide which instructs you to install the washers, sleeves, and nuts if they did not come preinstalled. As far as I can tell these things make installation on a 2020 401 impossible and must be removed before installation can take place.
Flip the spacer to the other side of the stalk for the clutch side mirror by removing the bar end bolt and the 5 #3 Allen bolts that attach the spacer to the mirror stalk. Flip the spacer to the other side and reinstall the 5 bolts tightening each to 3Nm before inserting the bar end bolt into the stalk and through the spacer.
Step 3) Installing the bar end mirrors
Ensuring that all sleeves, washers, and nuts have been removed and that the spacer is facing in toward the bike, hand tighten the bolt into the threaded bar until you can no longer reach and then fully tighten it with the #5 Allen key by rotating it clockwise. Tighten to 13Nm. Repeat on opposite side. These mirrors can be mounted either with the mirror pointed upward similar to the factory mirrors or downward to fall underneath the bars. I installed them facing up so I can't speak to the effectiveness of the mirrors in the downward configuration, but know that this is an option that is available to you if you wish to try it.
After installation roll on and off the throttle to ensure smooth and unimpeded operation. On my bike the grip wedged against the spacer and would not allow for smooth throttle operation. This can be remedied by either moving the throttle side controls further inboard and sliding the grip inward or trimming the grip inward so that the outside edge does not hang over the bar and sits flush with the bar end. Because I'm a bit lazy I opted for the second option and achieved a relatively clean result using a retractable razor blade and some patience.
Don't worry if it looks a bit jagged. Remember that the edge is going to be covered up by the mirror and spacer. Trim until throttle operation is smooth and unimpeded and then reinstall bar end mirror as before.
Step 4) Adjusting the bar end mirrors
This will take a bit of trial and error and will be a bit different for everyone. The mirror itself is on a ball mount and so it can be adjusted to a degree in all directions. Stand the bike up and look in each mirror from a seated position with your hands on the bars. Adjust the mirrors on the ball mount as needed until you can see behind you without seeing your elbows. If more up/down adjustment is needed than can be achieved with the ball mount adjustments alone this can be achieved by loosening the bar end bolts and changing the angle of the mirror stalk before re-tightening the bar end bolts. My shoulders are quite broad and I had no issue adjusting the mirrors in the left/right direction on the ball mount to get appropriate sight angles on both sides.
Step 5) Removing the factory mirrors
This step can be done at any point. You may find other steps easier if the factory mirrors are removed. I had no issues with this and removed the factory mirrors last, but do whatever you are comfortable with. The attachment point is covered by a rubber sleeve. Slide the sleeve up the stalk to access the bolts underneath. Using a wrench, rotate counterclockwise on the upper portion of the mirror to loosen it and then rotate the mirror itself counterclockwise to remove it. You will notice that the attachment is split into an upper and lower portion. The lower portion is a mounting point screwed into the bar itself and the upper portion is a mechanism to lock the mirror in place on that mounting point and should be loosened first. Unfortunately I tried to loosen the lower portion first on the throttle side and, in my frustration, I sheared the head off of the threaded mounting point for the mirror. I imagine it will be a massive pain to get out of there should I ever want to remove it so please learn from my mistake and loosen the locking bolt first. This may be easier using 2 wrenches with one holding the mounting point and one rotating the locking bolt counterclockwise, but I managed (somewhat) with only one.
Additional note: a question was raised regarding additional length added to the bar by these mirrors and the impact on ability to filter through traffic, so out of curiosity I decided to measure them. The bar end weights are exactly the same length as the spacer and stalk (~2.5cm) so no length was added there. The mirrors themselves add approximately ~5cm to the length of the bar on each side for a total added length of ~10cm.
Thank you for reading. I hope that this guide has been useful. I plan to make several modifications to this bike and I'd be happy to do additional write-ups for those installations as they happen. I did the best I could staying within the 5 image limit, but if that is ever raised I plan to do more detailed ones.
Tools/Parts Needed:
- #3 Allen key
- #5 Allen key
