NeverLost
When I started looking at the 401 Svartpilen, I really liked the bike, but didn't like the color scheme, nor the super short tail section. Then I saw the 2020! And it seemed to fix all that. So I bought one!
When I was shopping, I had been curious what all the differences were, so I made a list. And now that I am an owner I found a few more differences.
Here are the differences I see for the 2020 compared to the 2019. I also think these all apply to the Vitpilen.
First some pictures! These must be computer renderings because the images are perfectly the same except for the changes.
2020 left side
2019 left side
2020 right side
2019 right side
These are the differences I have found on the 2020 vs the 2019, 2018 and 2017 bikes.
The 2020...
2020 left side
2019 left side
2020 right side
2019 right side
The 2020...
- the new bike is now manufactured in India by Bajaj for Husqvarna/KTM
- new paint scheme and wheel color
- new adjustable front forks (compression and rebound)
- the 2020 has “Easy Shift” (quickshift / ignition shift cutout)
- the 2020 has a 40mm longer sub-frame/seat
- the 2020 exhaust is completely different and runs under engine (for euro5 emissions) (but the rear exhaust hanger is the same so the passenger peg delete kit works on both years) the new exhaust reduces the ground clearance
- new skid plate to protect the underslung exhaust
- the 2020 has metal plates built into in the tank rack for the magnetic tank bag
- new larger front fender
- new rear license plate mount
- rear blinkers moved to the tail section
- different/larger rear brake fluid reservoir
- all of the body panels are slightly different. You cannot put the 2019 panels on a 2020
- the 2020 seat is longer, a 2019 seat will not fit on a 2020
- 2020 has a metal gas tank, 2019 was plastic
- 2020 handle bars have plugged ends with a threaded insert for the bar end weights. This makes installing bar end mirrors different (or harder)
- interestingly, the 2020 has quality control witness marks on many of the nuts and bolts all over the bike (these are easily cleaned off)
- many of the torx bolts that were on the 2019 have been replaced with hex or phillips head hardware on the 2020
- airbox is changed on the 2020
