801 heat shield to protect the indicator (turn signal) at the muffler
@Eanes looks good, but why do you need a heat shield with the stock license plate holder?
Here's another set of pics that shows the geometry of the heat shield a bit better; maybe it will help if someone else also wants to fabricate it; it still works absolutely fine.
Bonjour , j'avais compris que le clignotant fondait avec le support d'origine en cas de roulage un peu rapide sur autoroute .... et puis cela me plaisait de le faire , et finalement je suis fier de moi d'y être parvenu .
Hi! I’d heard that the turn signal melts along with the original mount if you ride a bit briskly on the highway... plus, I just enjoyed doing it, and ultimately, I’m proud that I pulled it off
No, you misunderstood that. The stock turn signal can melt if you have a short tail tidy combined with either the stock exhaust or another long exhaust.
As long as the original license plate-holder/-bracket is installed, nothing will happen.
But could you please write in English from now on?
