Ergo seat
a_muz_ed
Belgium
I'm very happy with my new Vitpilen 801. Still breaking in, so once the first service is done, I can finally experience it's full potential. I really like driving the vit, it handles very well and gives lot's of confidence while cornering.
The standard seat is not too bad, but I get some pressure points after an hour or so. It would be nice if I could improve the sitting comfort.
Has anyone experience with the ergo seat for both the rider and pillion? Do they have a different shape compared tot the original seats or is it only the padding which is different? Does it offer more comfort or a slightly different sitting feeling?
Thanks for your help!
For some hours the stock Svartpilen 801 seat was absolutely fine to me; but at the end of a 300 - 350km daytrip of enganged riding on small back roads, my butt was always a bit "stressed" and I upgraded to the ergo seat (standard hight); and (to me) it's indeed better.
The shape of the seat is the same, just a different padding? I wouldn't mid switching just for the breathability, but I really love the stock shape.
I bought the ergo seat as well, was a lot worse than the normal seat for me. Your mileage may vary :)
I knew this would be an impossible question to answer. :)
Could you describe why it was a lot worse?
My gripes with the standard seat are that when I sit close to the tank, I get to much pressure on my soft parts. If I slide to the back of the seat, the side edges of the saddle are digging in the top of my hamstrings. So I hope the ergo seat can at least improve one position.🤞
Hmm, I'm quite petite and roughly 1,83 m and my hindside starts hurting after a bit over an hour and a half so I figured the comfort seat would be great for longer rides. The problem I have is that its situated further from the tank than the original seat so I cant sit properly on the bike and the cushioning is a bit softer but also with rougher edges on the side that cuts circulation to my legs after a while.
Thanks for sharing!
Unfortunately, that sounds quite familiar. These are the same pressure points I currently feel at the standard saddle. I'm also rather skinny (70 kg for 175cm) and for a comfortable riding position I like sitting on the front of the saddle. The back of the saddle is actually quite nice, bit indeed the edges start digging in my muscles at the back of my upper legs which start to ache after a while.
I was hoping the ergo seat would improve on these points, but based on your input, chances are small.
What you experience is very similar to what I experience as well.
I might give the ergo seat a try next time I go for a bit longer trip and let you know how it felt but last time it was not a pleasant experience :P
Thanks for the comparison pictures! Really nice and helpful to see the saddles side by side.
The more angular shape of the ergo seat looks promissing. The proof is in the eating, so I’ll give it a try.
Did you end up going for the ergo seat in the end? If so how did you get on?
I’m considering getting an 801
I've ordered the ergo seat for both the rider and pinion and I'm waiting for the delivery. I'll report back when I've been able to test them.
The ergo seat looks identical to the Vitpilen seat except for the holes in the cover. I find the Vitpilen seat super comfortable, I put a couple hundred miles on it in one day before.
Bought an 801 Svart in the middle of winter. With my previous KTM experiences, I bought a tall ergo seat before riding the thing as the KTMs REALLY needed them. So far, have had the Husky out several times and no issues with the original seat for hour-plus rides. Looks like I may have wasted my money. My bad. Will try the ergo out at some point anyways. Too expensive to ship if I wanted to sell 🤷🏼‍♂️
I've received the ergo seats and I want to share some pics and initial impressions.
The shape of the ergo seat is - as far as I can see - identical to the orginal Vitpilen seat. The exterior is nicer though, a perforated fabric for the driver and a different location of the yellow stripe for the pillion. The other difference is the density of the interior cushioning, on the ergo seats it's a bit softer. I can see a different color of the foam (white vs yellow) through some holes in the backside.
I did some short back to back testdrives and the differences between both seats were subtle. When accelerating my butt gets pushed a bit more in the ergo seat, it's a bit more plush. Apart from that, little differences to note but I think only a proper long ride will give me the answer I'm looking for.
What about a lower Seat?
I cannot find anything given that iam 1.70 tall and might need to plan my feet on the ground with more confidence
There is lowering kit sold on the Husqvarna website but then again the bike isnt that tall.
