Battery Charger Permanent Cable Connection
Swannie74
Perth, Western Australia
Has anyone made permanent battery charger connections on their bike to make connecting easier?
was looking at the Ctek chargers, but don’t want to have to constantly disconnect cables etc when maintaining the battery 🔋
cheers
Yes. Installed ctek comfort connector. Routed the connector down to where Evap canister valve were located before i removed it. Strapped it to frametube. (Vit 701)
Did you connect directly onto the negative battery post or elsewhere on the motorcycle? If elsewhere, where? Thanks
What bike are you riding? My 2019 Svartpilen 401 came with a factory installed battery tender pigtail already attached to the battery........
And there is a spot to easily add a USB charger as well.
Does your bike not have either of these?
ECJ
I did connect directly to the battery negative and positive poles. A fuse on the positive cable would be good but i didnt bother with that.
ECJ
I haven’t seen anything like a battery tender install on my 2020 401 Vitpilen
Here's a pic of my factory set up. I use exactly the same thing on my other bikes. These pigtails can be bought separately, or usually come with Battey Tender brand chargers:
Are you certain the factory included that pigtail?
My experience says the dealers will sometimes install them as a courtesy to their customers.
My 2020 svartpilen 401 definitely did not come with this installed. I installed it myself shortly after getting the bike.
I have always assumed the pigtail was factory, as the dealership made a big deal about every other possible thing that could be pushed or mentioned, but this never came up. Looking in the manual, I see Husqvarna talks about charging the battery outside the bike, etc., so this would defiantly seem to NOT be a factory item. Thanks dealership!
Regardless, it is exactly what I do with every bike and certainly recommend it to the OP.....a note when installing: it is very tight under there, so make sure the leads are positioned in a way the seat does not press, or bind on the connections.
ECJ
