Hello
I have removed SAS and Evap valves with all of the crap. Made my own dongels to avoid fault codes.
Bought connectors from cycleterminal.com
1 Bosch Kompact 2 pole connector and 1 Sumitomo DL90 2 pin male connector. The Bosch connector fitted nice. The Sumitomo i had to slightly modify a bit.
I tossed the cable sealings that came with the connectors and managed to fit the resistors in the connector housing. Then sealed of the end with black silicon.
I used 2,2 kohm (2200ohm) 1/4 W resistors.
While i was fiddeling i turned the key before i had jacked in the dongels and
off course triggered the fault code.
But i was one step ahead and had ordered a Bluetooth OBD reader and a adapter cable and could reset the fault code when i had connected the dongles. Everyting worked out fine.
The easiest way is probably to just by ready made dongels. But want to share this in case someone want to do it themselves.
