Tail tidy and FuelX Pro+ Installations - Some Quick Tips
bonchef
Canada
Tail Tidy:
- it was not hard, but more sweat then I expected.
- main effort was re-routing the license plate light power. Will have to replace the LED soon, it came in yellow :|
- for the style I ordered, installing the four bolts with spacers upside-down was a bit of a challenge. Tip: keep three in place with tape, screw in the first one and then the rest would be easy.
- to re-install the chain guard without the plate holder, you will need to add a washer to one of the screws. Should consider adding a spacer too (I didn't)
FuelX Pro+:
- works as advertised, so far very happy on low rev maneuvering, no more choppy throttle. Currently experimenting at setting 4 and 5. Wouldn't want to crank it up mostly due to the small fuel tank we have :). Lite would likely suffice, but whatever.
- installation was a breeze - the vit instructions is adequate. Nonetheless:
- Side panel should be removed (not hard) for easier routing of the switch if you opt for that
- Was struggling with the sensor side connectors. I was pushing hard, only to realize you connect them by just pushing the lock back in. The lock will pull the connector in.
- I rather keep my tool bag, and the controller barely fits on top of the ECU
- the switch: there is actually just enough room for our clip-on - just loosen up the clutch lever mount point and tilt the lever down a bit if that works for you. The clutch lever actually works better for me at that angle.
IMG_20240726_204243.jpgIMG_20240726_155053.jpgLicense plate light power line re-routing
IMG_20240731_100514.jpgIMG_20240731_100521.jpgIMG_20240731_102748.jpgbetter for me at that angle
What made you decide on the Pro+ over the Pro or Lite?
Their pricing strategy. The lite is like the magazine rack in a bookstore to draw the crowd in, and then they up-sell you the presumably higher margin option. People like flexibility, and I am totally a sucker for that. LOL.
As for their performance improvement comparison chart, I would take it as a grain of salt.
