Which are the Galfer ones you have installed?
I also see on this Italian site that the rear disc has another image than the Galfer wave rear disc that we can see on the Projekt racing site, do you have a picture of the one you received?
Hello,
I haven't received my rotors yet as they are still in transit with FedEx. Unfortunately... I think I've accidentally ordered rotors for the cast wheel 401s. Here is the page from the
Galfer EU catalogue I used to find the part numbers to order:
Note that there is no listing for the 17-18 bikes, but 19 onwards list the DF940CW front rotor. Herein lies the issue - I have since confirmed that all spoke wheeled Vitpilen & Svartpilen 401 use the same front rotor regardless of model year. It seems that Galfer only sell directly the front rotor for
cast wheel 401s under their own brand... DF940CW is also listed for 390 Duke and RC 390, so definitely not for the spoked wheel models.
Rear rotor is the same between cast and spoked wheels for some reason, so I think I will be okay there.
I'm very sorry if I've misled anybody (
@toast449). I trusted the catalogue as my MY22 Vitpilen is EU market...
[...] have you changed the brake pads? I was seeing that on the website, which recommended us above, where you bought the cheaper discs also sell the Brembo pads, do you know if they are compatible with the system that we already manage and which pads you chose because they propose 3 different types or you stayed with the factory and are sufficient?
Here is an article with a friction coefficient chart (!):
Brembo Guide to the Right Pad
It was difficult to find English-language information on the various Brembo compounds - they do not seem to be widely popular/available outside of Italy. I ended up watching a review on YouTube in Italian with English subtitles. The consensus seemed to be that the SR compound (which Brembo classes as a race pad) is questionable for road use due to poor cold bite, even on heavy, high-powered motorcycles, so I decided to buy the SA (front) paired with the SP (rear).
Brief thoughts: SA compound offers improved stopping power with somewhat reduced lever effort compared to stock pads, with the exception of the very first cold stop where they are similar. Once they are warmed performance is much improved. I do not remember triggering ABS on the rear brake prior to installing the Brembo SP, where now the ABS threshold is easily reached with what I would consider to be moderate pedal pressure under all conditions.
@VIppen Apologies... it seems I've hijacked your thread.
