Hy to y'all, I'm new to this forum and I want to ask some questions
( Sorry if my English is bad is not my mother language)
So, I have the bad winners pc5 kit with the O2 sensor removal kit... My questions are these:
Is possible to install the O2 sensor kit delete without problems? It will generate a better afr on the low rpm and throttle part? And the bike will tune itself when weather changes and I go up or down on altitude?
The power commander 5 from bad winners and decat are used, the old owner told me that the bike will run better but from what I understand it will not auto tune itself to maintain the afr... It is true? And he said that he had troubles with the easy shift with the pc5 installed, he says that the gears are hard to get in and sometimes they will bounce back in a false neutral between gears... Even this is true? And if so.. I can modify something in the map with the C3 software?
Thanks in advance for the help
