Tubeless Kit for VITPILEN 401
GeoKrpan
Westlake Village, CA
Unlike tubeless for bicycles there doesn't appear to be sealant.
So I am thinking of converting to a tubeless on my Svartpilen 401 2023 but I wanted to know if the wheels have both the bead lock and the safety bead on them? Has anyone retired and confirmed or have gotten a confirmation from Husqvarna on this? Don't really want to convert without those features.
So looks like i answered my own question. Found the parts catalog and they have really nice cross section of the wheels and yes they have the bead and safety locks on them so no issue to go tubeless!
I hope you'll post an update once you've finished the conversion. After 3 flats in my first 6 months of riding, including one in Nevada hundreds of miles from the nearest open shop, I was this close to going tubeless but was talked out of it by my mechanic. No flats in the two years since, but in that time I've gone tubeless on my bicycles and I'll consider it again if the rims are well suited to it. Changing tubes with these rims was... not fun.
I've not gone tubeless on my road bicycles but lots of people have. Some have gone back to tubes. Their complaint is the difficulty of dismounting and mounting the tubeless specific tires on the rim, very tight fit. This is a problem because road tires are thin and light and don't last very long, need to be changed regularly.
Something I only recently discovered is TPU tubes. They're not made of butyl rather of a thin plastic film and weigh 30 grams.
I've had no flats on my 401, now with 3000 miles on the odometer. I was wondering, why not use Slime? It wouldn't be a mess when changing the tires because it's contained in the tubes.
PS I once did "ghetto tubeless" on my mountain bike. It involves mounting a tube to the rim, slitting it all the way around, mounting the tire, and then trimming off the excess tube that's sticking out. It totally worked.
I'm going this route eventually. Tubes are heavy and are rotation and unsprung mass. If you are going to drop weight this is an excellent place to do it. People feel the difference changing brake rotors and tube weight is much farther from the center of rotation.
This hasn't really been my experience with tubeless-ready rims and tubeless tires. Since I learned the trick of centering the bead in the spoke channel, I've been able to mount my tubeless setups without even having to use tire levers, and since most of the tires I like are tubeless anyway, it wouldn't make a difference (I'm assuming tires will go the way of other innovations that the cycling industry deems inevitable, with performance tires all going tubeless-ready and foldable even for road bikes, and only "entry-level" tires coming with wire beads). With the 401 on the other hand, changing a tube is a huge PIA, almost impossible with hand tools, at least for me.
Slime makes a version of their sealant especially for use in tubes, and there's another brand or two that seem to be more highly rated for the same thing. From reading the forums, it sounds like it's worked for some people, if not as consistently as tubeless with sealant. I don't think you could use a plug or anything, so any puncture larger than 1/8" would just be a mess. Probably worth trying before one of these tubeless kits which feel just a step up from packaged ghetto setups.
I've had tubed road bicycle tires that were nearly impossible to mount. Manufacturing tolerances in the rim and tire conspiring together. Some tires are so easy to mount yet I've never had one blow off the rim. I guess tire manufacturers are afraid they will. I'm reluctant to go tubeless because of this potential issue. At any rate, I don't believe that tire selection will make or break me. Guys buy $15k bikes and still suck, lol.
I reckon a nail makes a hole 1/8" or larger. I think if you get a nail in your tire you should not pull it out if you've got Slime in the tube. I have seen Slime for tubeless but mostly what I see from them is for tubes.
BTW On my ghetto tubeless setup for my mountain bike, the ammonia in the sealant eventually ate through the sidewalls as the tire was not tubeless ready. Neither was the rim.
Did you get the kit?
