Has anyone figured out the display connector pinout?
jacoalmi
Barcelona
Hi!
I'm new around here. So I'm not sure if this is the right place to post this thread.
I'm trying to build a new dashboard for my vitpilen, using a raspberry and a small screen, and I was wondering if it would be posible to use the original display connector.
I'm trying to find the connector pinout, but I can't find it anywhere. Has anyone figured out which wire is which for this connector??
Hi!
It’s given over across many pages of the wiring diagram in the Service Manual. I could transcribe the pinout but I’m unable to do it until a couple weeks from now.
Thank you!
Don't worry I've just bought the manual
You make any progress on this? Since the display is relatively useless and a little silly looking I was thinking of going with a Motogadget Tacho Classic and was hoping to tap in to some of the signals right on that connector.
Oh wow, definitely pricey.... So if I understand correctly, to do the rewiring, the pinout needs to be bought separately? is that the main challenge? Sorry I'm a total noob!
The display is a computer which gets its information from the ECU via the CAN bus. The data on the bus is encoded like the OBDii system in cars, but the data format is non-standard and proprietary to Husqvarna. Some of the indicator lights are hardwired and easy to figure out (high beams, neutral, etc.) but the tach, speedo, fuel, ABS warnings and other info is encoded on the CAN bus. Knowing the display pinout is the easy part… reverse engineering the CAN data format and programming a microprocessor to understand the data and pass it on to another display is the hard part. The folks at Motogadget and Bad Winners went through that effort but it’s non-trivial and requires mad skillz in circuit analysis and embedded systems design.
