Got a new Svart 401 - need help
qtravers
Seattle, WA
Thanks for letting me into the forum! I'm a 25 y/o brand new rider in Seattle, WA. Passed my permit course last week. Wish me luck on gaining experience for the endorsement course.
I recently purchased a 2019 Svartpilen 401 from a guy for only $3000, and given that I'm in a busy metro area but also love hitting the beautiful PNW lakes/forests, I thought the svart 401 would be perfect for me. Here's what I need help with:
The previous owner had to sell before he had the chance to put on a handful of performance parts, and he gave them all to me free of charge. Only thing he didn't get around to buying is the Powertronic ECU (not fuelx, the full fledged performance ECU). These parts include:
- comp. werkes chamber delete
- comp. werkes mini cat delete
- coffman shorty exhaust
- coober airbox mod
I absolutely want to squeeze as much power as I can out of my 401, as I want to keep it for awhile and grow into the power that this bike has to offer. Not quite in the position to just "buy a bigger bike if you want to go faster". These mods will work perfectly for me!
The only thing is, I live in a city and would rather the bike not be as insanely loud as 401 owners claim when they basically put a full exhaust on with no cat. Loud is just fine, but extremely loud is not.
I need help finding ways to balance performance and sound. Should I buy the Powertronic ECU needed to accompany these mods? If I installed all mods, would the stock baffle in the coffman exhaust be enough? If I installed chamber delete, coffman shortly, and coober airbox without de-catting, would that open the engine up enough to warrant buying the ECU? Do I need to get rid of the cat to get a performance gain? I'm stuck between really wanting to squeeze more power and weight reduction, and playing around with different fuel maps vs just putting the coffman slip on only.
I understand noise levels are up to interpretation and what's loud to me, might not be for someone else. However, I would prefer performance over too much noise. I just want a way to reduce noise while still having max performance. Plz help!!
Second thing: I wanted to try a 16t front sprocket for a little more top end on the freeway, but was hoping that I would still have good low end power given the performance mods. Any thoughts?
I recommend you to put the chamber delete and the exhaust without DB Killer buuuuuuut to put the CAT again. In fact we all want the best balance between sound and performance and this balance seems to me the best for your use.
I have:
- Powetronic V4 ECU
- Fuelx Lite
- Airbox filter stage 2 DNA
- Air box filter stage 1 DNA
- Werkes Chamber delete
- Werkes exhaust
I can tell you that it's night and day between the bike before and the bike after these changes. I felt like I was given another bike literally in every aspect, performance, low revving behavior, acceleration behavior, high revving behavior etc.
The only thing for performance that I didn't remove is the CAT and only for sound, it's too much and it's literally just for the track in my opinion.
To gain in performance you can remove the maximum weight, the plate support weighs about 3kg if I'm not mistaken, the same black camera, you can buy and remove the EVAP System that also weighs a little, but I do not know how it is in the 2019 model, my Vitpilen is 2020.
I have:
- Powetronic V4 ECU
- Fuelx Lite
- Werkes exhaust
I really appreciate you replying and giving me the much need info. So to confirm, you’re saying put all mods in, except DONT take out the cat pipe?
Also I notice you have both fuelx lite and v4. Is this necessary? How well off would I be with just v4?
Lastly, have you done any sprocket changes? Initially I didn’t want to lose out on low end torque by doing a 16t up front. But given that the performance of the bike is increased by the mods, that may offset any low end performance losses and allow for better highway riding. What you think? Thanks again
I put the FuelX Lite first and then I put the V4, so I can't tell you if the V4 alone is enough, but the V4 is not connected to the gas sensors, it is connected to everything else. I still recommend you to start with just the V4 if you were already planning to buy it and see if it is enough for you.
When I put the FuelX Lite, with the two filters, chamber delete and open exhaust, I saw that thanks only to the FuelX Lite, the bike behaves much better at low revs and makes you shift less and then you use less your clutch and that is much more pleasant for driving in the city. It also changed the torque and acceleration a bit. Since it is 2 times cheaper than the V4 you can start with just the FuelX lite and then see if you want even more with the V4. I decided for the V4 not because I wanted performance but because I wanted to avoid any problems with the engine for all my modifications and normally the V4 is more useful than the FuelX lite for this aspect and calculate all the needs of your engine and mapping according to your use and your mods of the bike.
I have never removed the CAT and I don't think I will do it unless I go on track, because in all the forums or videos I saw without CAT, they put the CAT back on because they say the sound is too loud without the CAT. Only with the chamber delete and the exhaust I can tell you that it is more than enough and they hear you from far away. And I am a lover of good and loud sound haha.
I still use the same sprocket and I easily reach 160 km/h, I don't know exactly what you mean by better performance on the highway? This little bike just has everything in its acceleration, me personally, but that's up to each one, I would not change this part to have better top speed, because just the torque and acceleration is what makes that we can play with higher cylinder capacity bikes in the curves here in the mountains.
This info is incredibly useful, thank you so much! After some further research, it seems that the fuelx lite helps with idle, and the ECU helps with A/F ratio during acceleration. I'll likely get both.
This has been a huge learning experience for me: my first motorcycle, first time working on a combustion vehicle without taking it to a shop, first time learning how to do eletrical work, etc. So I want to keep learning the best I can without going to a shop and paying even more.
When you installed the Powertronic v4, did you do it yourself? How easy is it to learn how to not only install, but mess around with fuel maps and the software? Thanks!
It is also the first time that I did everything by myself and got my hands on the bike, but the truth is that all these modifications are easy and purely electronic, not mechanical. There are also many tutos on youtube for both Fuelx Lite and V4 but if you need any help or advice let me know.
I just installed my V4 a couple of weeks ago, and I put the default maps on them. One is for enhanced use and the other for racing. I have not yet taken the time to study the programming and software, I want first to see how it goes with the "racing +" map. The installation is easy, it just takes time, I was very bad with these things but I learned with all the info online and it is not difficult at all.
First time on a forum, you guys are so helpful! Last question: have you done anything to make the seat more comfortable?
I tried to order an Ergo seat but it was not in stock on the internet and it is too expensive at the agency. I will try to do it here where I live, it will surely be cheaper. The option that I have right now is a cyclist's lycra under my pants since all my outings are for a minimum of 6 hours on the bike and it is not bearable only with the normal seat. It is a cheap solution and also helps a lot.
Awesome, I'll look into that. I lied, not last question. Do you have a bike cover? I dont always want to bring it into my apartment, so I'm thinking about getting one. Does a generic one work fine, or have you gotten one made for the svart 401?
I have a generic one, my motorcycle sleeps outside but it hardly rains where I live and anyway it is covered where it stays, nothing more than if it is outside not in a garage
Saw this on a YouTuber's site...you can not beat the price...and it makes a huge diff. Somehow this product, while having NOTHING to do with Husqvarna...works.
It does take some modding and careful install, but once done- that's it. Highly recommend, for the money, it was worth it. I ordered the Ergo seat and it finally came in a year later...I still use this cover/pad and am enjoying "double" the relief.
Here's the video I saw:
I see you are in Mexico, but a hope Amazon can still deliver with little effort.
Good luck:
I have always stayed away from electronics when it comes to motorcycles but I installed the Fuel Ex in about 30min with the help from YouTube. It’s not hard and the effects are noticeable.
I have read from several owners that the cat delete and even the camber delete makes the bike slower, so I won’t be doing that.
