Stock muffler reimagined
Liteway
Choctaw Okla.
Not doubt some like it, but the thin stamped metal heat guard on the muffler did not appeal to me
I do appreciate the subdued sound levels coming from a stock muffler though.
It compliments the bike's non-threatening styling and allows me to buzz about aggressively with minimal concern coming from other motorist.
It's stealthy.
So, I did a bit of custom work on the stock muffler.
Removed the guard, ground off the mounting tabs and resprayed with some Duplicolor engine paint.
Could have gone silver, but the black better hides some slight overgrinds into the soft aluminum.
I was amazed at how light the muffler is , probably 1/2 the weight of the steel Japanese midsize bike mufflers I have owned in the past, but then they did not have cats and prechambers either.
The red vinyl stripe is just a trial and is easily removed or color changed.
I am curious to see your job but the it seems the link don't works, could you post pictures?
As a follow up, not sure I would do it again. The muffler under the guard is pitted in places as it comes from the factory. I used aluminum solder to fill the worst of those.
You have to be very carful cutting and grinding the aluminum brackets that held on the old guard to not create any low spots.
The new finish is already showing some light scratches and though it is easily redone, it will never be as resilient as the original finish.
I think it is a good idea should the guard be damaged in an accident, otherwise not worth the effort.
The latest idea: home made burn guard, raw .05 sheet aluminum. lots of holes, spaced about an 8th inch over the muffler. I used a random orbital sander and a Scotchbrite pad for finish, then a light rubbing with an aluminum polish.
Any scratches that might appear will be easily dealt with.
