NeverLost
I'd consider changing the mirrors, shortening the rear fender / tail tidy, and looking for any heavy parts that might need removing...
It almost certainly has a canister and valves...I used to own a KTM 950 Super Enduro and one of the most popular mods was to remove the SAS/EVAP canister system (can't remember exact name).
Does anyone know if the 890 has a similar system that "should" be removed?
Thanks for your response!It almost certainly has a canister and valves...
Husqvarna.SparePartsFinder
sparepartsfinder.husqvarna-motorcycles.com
Rottweiler has a video about this: Here I was planning on buying the 890 Adventure R but then the Norden was announced so I jumped ship. My plan was to remove the canister and install my Denali air horn but it might be slightly different on the new Norden....I'll find out in a couple of months time.It almost certainly has a canister and valves...
what is this ECU about ? could you exoplain a bit ?![]()
HQV 901 NORDEN LM ECU - COOBER
COOBER HUSQVARNA 901 NORDEN LM ECU. The only ECU on the market with full EUR4 / EUR5 support. Pre-Configured and Plug-N-Play.www.coober.eu
Thanks for the link! No SAS on 790/890, that's good. Removing canister seems quick, easy and cheap!Rottweiler has a video about this: Here I was planning on buying the 890 Adventure R but then the Norden was announced so I jumped ship. My plan was to remove the canister and install my Denali air horn but it might be slightly different on the new Norden....I'll find out in a couple of months time.
The ECU is the Electronic Control Unit and is the main brain for the bike. The Coober ECU I am guessing is a performance replacement over the stock ECU. The theory is it will change varies settings that are already programmed in it and thus give you better performance from the engine. It will void your warranty is the drawback. At least that's how they work for cars/trucks.what is this ECU about ? could you exoplain a bit ?
