Today I’ve installed a smartphone braket. Fit perfect, and the phone is exactly on the line of the eyes for navigation and to control the messages.
I was unable, however, to do exactly what I had in mind. Because under the housing of the braket there is the acc2 cable, which has the positive locked up, to which I wanted to connect a USB socket and then only the end of the cable I need to connect to the smartphone comes out, instead of using the Din socket with the adapter and the disconnecting cable. Unfortunately, it seems there is no current in the acc2 cable!
The wiring diagram is not available in the manual, not even in the one of the Ktm 890, very badly, I would have tried to check the connections and maybe fix the problem, instead I'll just have to check the fuses before taking the bike to the workshop.
