Side stand wiring delete
Freedom51
australia
Should anyone want to disable the side stand switch , this is the easiest way .remove the seat ,the left hand tank cover has 4 screws 1 at the front 1 under the tank buffer with the H on it,1 near the airbox and 1 hidden as show in photos ,the LH air intake has a screw as well ,all come off as one .The connection is hiding in front of the ECU connector , I use needle nose pliers to retieve it .hope this helps
