pinout diagrams for dashboard display
vinto
Philippines
My dashboard got water damage and
I’m trying to install aftermarket universal dashboard for my svartpilen.
I'm trying to find the connector pinout, but I can't find it anywhere. Has anyone figured out which wire is which for this connector? I need some diagram illustration. Thank you
Hi, installing a universal cluster won't work, the bike uses a CAN-bus digital system where data is transmitted in encoded packets rather than simple pulses.
A pinout won't help you because an analog dash simply can't interpret the ECU signals for RPM, speed, or gear position.
Your only realistic option is buying an original used unit, you can buy it online and track Maersk containers in real time, or attempting to have the old board repaired at a electronics service.
