Muffler replacement
dakaroo
Peso of the North, Kelowna BC
I'm just looking to replace the factory muffler for little more sound. I have a 2021 401 and many companies only list up to 18 as workable. My question has the big black can in front of the rear shock changed on the output side to the muffler or has that stayed the same? Thanks for your input :)
I have a 2020, so not sure of what has changed but I bought a Coffman slip on (they have one specific for 20-21) for the exact reason you want it, just a little more sound. After I installed it, it's exactly what I was looking for. There are two baffles that can be removed to make it even louder, but for me it's good as is. They will also make it without the name place if you include a note when you order. It's also affordable compared to other options and is very well made. This is just a muffler change, so everything else stays the same which is what i wanted. I didn't want to start messing with the performance or possibly removing too much to the point that a retuning or performance ECU would be needed.
Second this. Have the debadged Coffman shorty with the baffles installed. Great sound. Louder/lower throaty tone compared to stock and importantly not obnoxious sounding. It is specific for the 20-21 flange angle.
2018-2019 is different then 2020+, 2020+ is the same so far.
Which sound change exactly are you looking for?
All pipes will change the sound a bit, only the "show use only" or "not road legal" setups will increase the volume.
For increased volume I can fully recommend either the Coffman's Shorty (with stock black box), or the Comp. Werkes Delete (with stock muffler). Both have excellent welding, and I especially like the Black Coatings that both Coffman's and Comp. Werkes offer.
For change in exhaust note, any name brand Slip On will give you a unique tone, characteristic to their branding.
My son has put a Delkevic on his DRZ400 he can be heard on the road with a braap braap but not crazy loud, he left the baffle in, since I have amazon $ in Canada I'm looking at Delkevic, it to bad Coffman doesn't sell on Amazon.ca, they do sell on ebay, except I dont have ebay $
No cat/premuffler in a carbi drz, so that delki braap noise isnt gonna be anything similar to what you could expect to get with a 401 by only changing a slip on.
If its only about braap noise what about a Werkes chamber delete? Then you can keep the stock pipe/look on the bike.
Not sure what all amazon stocks there, I have sometimes seen good deals on pipes directly from amazon, and not ones from sellers on amazon.
I understand the comment on the drz. I want to stick with slip on as I don't want to do the ecu piggyback and tune. I think the first step might just be to drill out the rivets on the oem muffler and cut off the db killer, perhaps I'll get lucky and get the increased sound with no real cost?
Please dont. I have two stock mufflers for that reason... and it was a waste.
Their are options that are cheap that dont destroy a tuned muffler.
I still would recommend the Werkes chamber delete to equal proportions as I recommend the Coffman's
If you only go chamber delete you do not need to tune anything, it will not add or decrease horsepower, only change sound and feel a bit... if it feels faster its the weight.
