Lightweight Nakeds Comparison Chart!
HQVa Admin
Administrator
Staff member
California
From motorcycle.com
SpecsBMW G310RHusqvarna Svartpilen 401Kawasaki Z400KTM 390 DukeYamaha MT-03
MSRP$5045 (base)$5299$4999$5699$4599
Engine TypeWater-cooled, single-cylinder 4-stroke engine, four valves, two overhead camshafts and wet sump lubricationLiquid-cooled, four-valve, DOHC, Single cylinder4-stroke, 2-cylinder, DOHC, liquid-cooledLiquid-cooled, four-valve, DOHC Single cylinder, 4-strokeliquid-cooled DOHC 4-stroke; 4 valves
Displacement313cc373cc399cc373cc321cc
Bore and Stroke76.2 mm x 60.96 mm89.0 mm x 60.0 mm70.0 mm x 51.8 mm89.0 mm x 60.0 mm68.0 mm x 44.1 mm
Compression Ratio10.9:112.6:111.5:112.6:111.2:1
Horsepower
(measured)
31.8 hp at 9500 rpm37.9 hp at 9200 rpm43.2 hp at 10,200 rpm39.8 hp at 8800 rpm36.4 hp at 10,800 rpm
Torque
(measured)
19.7 lb-ft. at 7500 rpm22.1 lb-ft. at 7000 rpm24.5 lb-ft. at 8200 rpm25.8 lb-ft. at 7000 rpm20.1 lb-ft. at 9100 rpm
FuelingElectronic fuel injectionElectronic fuel injection system, 46 mm throttle bodies with Ride-by-Wire systemDFI with 32mm throttle bodiesElectronic fuel injection system, 46 mm throttle bodies with Ride-by-Wire systemFuel injection
TransmissionConstant mesh 6-speed gearbox integrated in crankcase6 speed w/autoblipper6-speed6 gears6-speed
ClutchMulti-disc oil bath (anti-hopping) with self-reinforcementmulti-disc slipper clutch, mechanically operatedmulti-plate wet clutchmulti-disc slipper clutch, mechanically operatedConstant mesh; wet multiplate clutch
Final DriveChainChainChainChainX-ring chain
FrameTubular steel frame in grid structure with bolt-on rear frameSteel trellis frame, powder coatedTrellis, high tensile steelSteel trellis frame, powder coatedTubular steel
Front
Suspension
41mm inverted fork, non-adjustable; 5.5 in. travelWP 43 mm usd fork, compression, rebound adjustable, 5.6 inches of travelTelescopic fork/4.7 in travel43mm WP inverted fork, non-adjustable; 5.6 inches travel37mm KYB inverted fork; 5.1-in travel
Rear
Suspension
Single shock, preload-adjustable; 5.2 in travelWP-USD Ø 43 mm, 5.6 inches travelUni-Trak swingarm/5.1 in travelWP shock absorber, 5.9 inches travelSingle shock; 7-step preload adjustable, 4.9-in travel
Front BrakeSingle disc, diameter 300mm, 4-piston fixed caliper, radially boltedByBre four piston, radially mounted caliper, brake disc Ø 320 mmSingle 310mm disc, twin-piston caliper, ABS320mm single disc, radial-mount 4-piston caliper, ABS w/Supermoto modeHydraulic single disc brake, 298mm; ABS
Rear BrakeSingle disc, diameter 241mm, single-piston floating caliperByBre single piston, floating caliper, brake disc Ø 230 mmSingle 220mm disc, single-piston caliper, ABS230mm single disc, single piston, floating caliper, ABS w/Supermoto modeHydraulic single disc brake, 220mm; ABS
Front Tire110/70 R 17Pirelli Scorpion Rally STR 110/70 R 17110/70 R 17110/70 x 17110/70 R17
Rear Tire150/60 R 17Pirelli Scorpion Rally STR 150/60 R 17150/60 R 17150/60 x 17140/70 R17
Rake25.1°25.0°24.5°25.0°25.0°
Trail4.5 inches3.7 inches3.6 inches3.7 inches3.7 inches
Wheelbase54.3 inches53.4 ± 0.6 inches53.9 inches53.4 ± 0.6 inches54.3 inches
Seat Height30.9 inches (Standard Seat), 30.3 inches (low), 31.5 (high)32.9 inches30.9 inches32.7 inches30.7 inches
Curb Weight
(measured on MO scales)
363 pounds359 pounds360 pounds363 pounds371 pounds
Fuel Capacity2.9 gallons (Approx. 0.25 gal reserve)2.5 gallons3.7 gallons3.5 gallons3.5 gallons
Cool article.
I didnt know I had a 4 piston front caliper...
And what bike is it showing for the 401 front wheel... 5 spokes that are twisty, abs ring cover, aerodynamic fork guard...
Wonder where they got the power numbers. All I ever saw for the 401 was 40HP+ when I was shopping and choosing between it and the Kawi.
HP (measured) is what it says, not sure how much confidence to have on their numbers when the pics for the pilen are of atleast 3 different bikes...
Also would point at the weight...
Whats interesting is...
KTM Dry to measured 35 lbs. - fuel = 13 lbs.
HQV Dry to measured 24 lbs. - fuel = 8 lbs.
Where are the 5 lbs... 🤯🤯🤯
I mean between the two bikes, oil and battery, etc., should be the same... thats where I wonder about the 5 lbs...why does the duke have 5 lbs worth of additional oil 🤦‍♂️
How can the Svart and 390 have different hp figures, exact same engine, frame, transmission, etc. Interesting that the Z400 is only1lb heavier with 1.2 gallons more fuel. If that made that in an RS cafe that would be a nice ride.
I can easily see that the two duke type bikes have different Horsepower figures because of the weight; in order to have A2 the power to weight ratio is limited from what I understand, and software is easily tuned.
But yes, the figures are strange, maybe the Kawi uses helium fuel...
