Issues with Fuel-x Lite?
pilenlover
Boulder, CO
Hello fellow 401ers :). Thanks in advance and sorry if this has already been addressed and I failed to find it.
I have a 2021 Svart 401 that I have made a few mods to, including...
- K&N air filter
- Leo Vince slip on exhaust (love the sound!)
- Powertronic FuelX Lite.
I installed all 3 at once, but feel the issue I am experiencing is due to the FuelX and would love to hear thoughts and suggestions.
The issue is intermittent. The engine cuts out upon hard acceleration, not enough to stall: the engine "recovers" without me having to restart and I can continue on my way, but it is a problem and unsafe IMO. It doesn't happen all the time by any means. I also don't hammer the throttle every time I pull away, but it happened a few times during my last ride (hotter weather?). I really need to figure this out.
Some of my thoughts. Do any of these seem most likely?
- could this be a loose wire or ground?
- faulty unit, should I contact the manufacturer?
- could this be exhaust related instead?
Has anyone else experienced this problem with this unit?
Thanks in advance!!
Do some rides and make sure your shoe isn’t touching the gear lever. If your foot is touching the lever, the ECU might cut the engine because it thinks you are about to shift gears.
