Instrument cluster
Guy Pike
New Hampshire
Will the 2021 Vit run with the instrument cluster totally removed? The LCD display really is a pain and full of info I don't care about. I'm pretty sure that an after market tach which is quite readable can be installed and the ABS have been done a way with already.
Themis tiger country that your talking about and i doubt the ECU would appreciate it.
More homework required.
Was that a drunk reply?
I'll let you know in a bit, I would like to remove that eyesore and replace it with a motogadget gauge. Also, I would like to remove the ABS as well - you just pulled it out and ran new brake lines?
Not drunk...just cautious.
Not knowing the implications with any certainty i prefer to test the waters before diving in head first. This is what Guy Pike is correctly doing and since no one has chimed in with specific knowledge it looks like it's uncharted territory....tiger country.
Everything works, I went for a long ride and tested everything. I do have signals, look closer. motogadget bar end signals up front and pins in the back.
