Hello,
my brother has bought a 2007 model Husqvarna SM610IE.
You need iBeat for this, which apparently doesn’t run on current versions of Windows.
That’s not entirely correct: it doesn’t run on 64-bit versions.
By creating a registry key, iBeat can also be launched on Windows 11 64-bit.
Todo:
Install iBeat from well known iso file
Create a textfile with name "iBeat-win11-fix.reg" an insert the following text:
Import the file by double click and confirm the following question.
Now, you can start iBeat.
I can't test the function, but it should work.
Best reagrds from germany
Daniel
Todo:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\08E3619248C58A341BEE8E134E06A75F]
"B08AEBA7A80F0B740B3CFE6202C08E88"="C:\\Program Files (x86)\\ibeat\\iDT01.exe"
Daniel
