It was time for the first oil change on my 2020 Svartpilen 401 and I decided to take some pictures and document the process.
Oil changes are generally pretty easy. But I should note that it is a bit harder to do on this bike than many others. It has the usual filter that you have to change, plus two mesh screens that you must manually clean. Also, you must remove and replace the skid plate / spoiler. (Really, Husqvarna calls it the “front spoiler” in the manual!)
Stuff you need:
There are 6 screws, three on each side. The ones one the left side are hard to reach and will require a socket extension. Note that on my bike (and I have heard on others) these 6 bolts are “tight” to remove.
Right side.
The bolts on the left side are hard to see. You will need a socket extension to reach these.
Since the threads seemed poorly formed I used my tap and die set to chase the threads in the engine and to clean the threads on the bolts. This was fairly tough as I didn’t have an extension for my tap. Also note the tape on the tap marking the depth of the bolts. If you don’t have a tap and die set, consider getting a spare bolt and running it in and out of each hole couple times, cleaning the hole out with compressed air each time and cleaning the threads on the bolt with a brush. The bolt should run in and out smoothly.
Check out all the witness marks on the bottom of the skid plate. I cleaned these off with a bit of WD 40. I also found a nice gouge in my skid plate from my short off road test. I guess it works!
Stuff you need:
- the manual with instructions and torque specs (download it from the Husqvarna site.)
- 2 liters of oil (see the manual and maybe the infamous oil thread)
- oil filter (I used the K&N Oil Filter: KN-155)
- stuff to clean the mesh filters (compressed air, plastic/nylon safe spray solvent)
- piece of cardboard to keep your driveway clean
- oil pan and rags
- funnel
- torque wrench (OK, you can do without this, but over or under tightening these bolts can easily result in disaster!)
- assorted sockets, pliers and other tools (NOTE: The bottom drain plug can be hard to reach to with normal tools. Some have reported needing to loosen the exhaust to reach it. It also may be easier to get at with a thinner 1/4" drive socket and extension.)
- spare set of mesh screens and o-rings
- It is best to have a spare set of o-rings and mesh screens available in case some need replacement during the oil change. You could also just replace the screens instead of cleaning them… but I recommend cleaning them most of the time. Oil change service kit: https://www.amazon.com/KTM-FILTER-SERVICE-2014-90238015010/dp/B00W87DYBU/
Right side.
