Husq will not extend warranty for TPS issue due to aftermarket exhaust
96d7d73
NYC
I've been going back and forth with my dealership and Husq on a 2019 Svartpilen 401 for the past year about an ongoing issue that the dealership finally fixed where the bike would gain and lose speed on its own in any gear. I suggested that the fuel injection / sensor was off which would explain why the bike would still be running, but the RPMs would go up and down on its own. This is what I've been told:
  • Dealership says there was a faulty pin in the TPS (Throttle Position Sensor) and they "fixed" this
  • Then upon further test rides, it was having the issue again, and they performed a reinitialization run which calibrates the throttle body and sensors
  • The initialization run "calibrated the throttle body and EDU to adjust to readings with the aftermarket exhaust"
Prior to this Husq sent me an email saying they would give me an extended warranty, but now is claiming that the issue the dealership fixed was caused by the aftermarket exhaust (Leo Vince slip on). Under the Magnuson Moss warranty act, an aftermarket part should not void a warranty, unless it affected the function of the bike. I am no engineer, but something does not seem right with this diagnostic. I rode this bike for 1000 miles with aftermarket slip on and did not have any issues. It started soon after the ABS went light on, which was due to faulty wiring/ABS sensor - both of which have since been replaced under warranty. Does anyone have experience with this? I'd love to see the repair manual as well if you have it just for my own edification.
