Has anyone replaced the horn with something a little less feeble sounding?
I purchased a Denali SoundBomb Mini as I believed it would be a straight swap for the original but it neither fits on the original bracket or works with the wiring harness. The bracket can easily be swapped or I can drill the hole for the slightly wider thread but it just makes a small click sound when pressed so I'm assuming its trying to draw too much current. Looks like I will need to make a separate wire fuse relay connection. Does anyone have the wiring schematics handy or know if there is a spare spot in the fuse / relay box to use as I would prefer it to be neat and not wired directly to the battery.
