False neutrals
SvePil
Sweden
Happy with the bike so far. But having problem with false neutral shifting from 5 to 6 gear. Only got about 50km on the bike and maybe it need som more time to break in all parts. Otherwise i gues a stronger shift spring will do the trick?
Anybody of you guys exerience the same problem? Have you tried the shift kit with the stronger spring?
Hi @SvePil
We all have it every now and then I guess. It's the return spring from the shift mechanism (or whatever they call it). Some have it worse then others. There is a solution for it.
I adjusted the shift lever a tad down to make sure my shifts are at least well executed. I may change that spring one day. Luckily it doesn't happen often on mine.
That's a god move. I will move my lever to and give it at try.
Thanks Max
How many KMs do you have?
My 401 did it atleast 1 in 10 shifts from 5 to 6 until recently.
It felt like around 9.5 thousand km everything settled in.
Since then its happened once in 1000km.
(And i was to blame cause i missed...)
Missed one zero in original post. Have done 500 km so far. Vill give it up to 1000 km then maybe do the shift kit install.
I also adjusted lever and it helps, still get it ever now and then, but it is my fault generally.
I have adjusted my lever to but have not been able to try it. The weather playing tricks on me here. But i am sure it will help now. Gets a little more uppforce on the lever now.
It is the shift mekanism that not fully engage between gears. You have to be consistent? With the shift movement if you se what i mean. Excuse bad english here😊
