Installed some CNC Swing arm Sliders Spools for the bike today. I purchased them from Amazon with the following link.
Additional hardware and a spacer was required for this install if you want to retain the rear tire hugger.
First Impressions, quality wise I think they are quite good and work well with my swing arm stand. They scratch quite easily being powder coated aluminum, every time I use my stand I place a thin rag to cut down on the scratches. The M10 1.5 mm hardware supplied with the kit fits the exhaust side well. I wanted to retain the rear tire hugger so I needed to purchase a longer M10 1.5 mm. I have found that a 50mm long works and a 70 mm is too long. I'm using the 50 mm but looking to purchase a 55 to 60 mm in the future.
I made my 1/2" spacer using a nylon nut that I ground the edges down to the same outer diameter as the socket head cap screw. The nylon nut also keeps the bobbin set tight on the socket head cap screw. I needed an additional spacer to get to 1/2" so a few modified washers did the trick. Make sure anything you use as a spacer is not bigger than the socket head of the M10 screw. Any bigger will run the risk of cracking the cast aluminum tire hugger.
This could be done with a hand file but recommend using a bench grinder to make the spacer.
