Clearance: Header / Magneto Cover 401 '18-'19
champion rider
I was playing with my exhaust and I decided to clock the header to exactly the stock position and with it there, I measure 1.7mm (about 1/16 in.) of clearance between the header and the magneto cover.
When I clock it to give a bit more clearance I end up with more or less exhaust leak... before or after the cat.
Alternatively once the gaskets are crushed a few times remove/replace, it seems to fit best with the header touching the cover...
I figure that this has to do with this particular production lot of my 'pilens frame, as this appears to be determined by the position of the motor mounts relative to the chamber mounts.
How much does everyone else have?
