TLDR; I have some black and white corrosion on the zinc plated parts which is hard to shift, and impossible to get shiny again. Also the black spokes have some white speckley appearance which won't clean off, I assume also some kind of corrosion (also on the wheel speed sensors). Anyone have any experience with this. Trying to get the bike in good condition to sell asap, but it may require recoating, or replacing the spokes and spoke nipples to resolve it. In which case I will just have to sell it as is.
Hello all, first post on this forum and new (ish) Svartpilen owner.
So basically I have been riding my 2024 Svartpilen since June last year when I bought it and I used it basically every day to commute to and from work, come wind rain or shine (except for a couple of days where the roads outside my house iced over). I actually bought the Svartpilen 125 but it is relevant in the 401 section as much of the bodywork is identical or similar in design between the bikes.
I recently got my full motorbike licence and have now bought the 2024 Svartpilen 401 at the beginning of March as my first upgrade. I actually moved a bunch of mods straight over from the 125 to the 401 as the chassis is practically identical. I've returned the bike to stock configuration, but currently giving it a good strip down clean before I sell it. Of course it would be preferable not to ride the bike at all through the winter but it is my main form of transportation currently.
I did use rust protection (XCP professional Clear Coat) which I applied once around the beginning of October, and again in early January. The first time I applied it everywhere including the wheels and spokes (not on the discs), but the second time I only applied it to the body (the wheels were completely covered). I didn't clean the bike as often as I probably should have, every couple of weeks; and it didn't help that for much of the year I set off and arrived home in the dark so I didn't notice the beginnings of corrosion in some areas.
Overall though there is not too much corrosion. The exhaust header has gone a little brown but it isn't too bad (I think some general maintenance spray should have been used on it) and I got a couple of red spots on the outside of the rear chamber but these have brushed off relatively easily. A couple of bolts connected to the exhaust have gone rusty though (I think the XCP stuff burns off at too high temps). The rest of the chassis is pretty much fine, except for some zinc coated parts.
The front axle got affected quite badly, although that may be due to the aluminium end caps (for the front crash bungs) causing some electrolytic corrosion maybe (there was a lot of white solid stuff around where the end caps touched the axle). Much of the black coating on the front axle has turned white and flaked off completely, although this isn't too much of an issue as it will get covered liberally in grease when I reassemble it.
The front disc also got quite dirty and some rust appeared around the edges. It took some time to clean with wire wool but it is now looking practically new.
The wheels though seemed to get affected quite badly, mostly the spokes and spoke nipples. The zinc coated disc bolts and spoke nipples have gone partly, or completely black. While the spokes have a speckley white appearance which appears to be some kind of white corrosion as it does not come off at all no matter what I try without taking off the coating completely (are the spokes black zinc coated?). The wheel speed sensors also seem to have some faint white discolouration which won't wash off. Does anyone have any experience with this type of corrosion? Can it be cleaned off or does it need totally recoating with something like paint?
I should be able to provide some pictures tomorrow.
