One might want one of these if they were thinking of removing the evap canister and the rest of the plumbing for track days.
If you want to remove the valve, you need to replace the valve with a "dongle" including an appropriately sized resistor to avoid the engine check light coming on. Since no one makes one of these for the 2020+ 401 bikes, I decided to try and make one myself.
(Post updated as I modified the project a bit.)
A little testing showed my stock valve to be about 24 Ohms. The lower the resistance, the higher wattage is consumed.
W = (V^2)/R, so if we assume 14V and 24Ω that yields 8W. That would be a pretty large resistor.
Increasing the resistance to the standard size of 39Ω yields 5.0W. Hopefully the battery regulator works and the actual voltage is lower than this. If you try this, I'd suggest using an even larger or higher wattage resistor.
I did test the resistor on the bike, and it worked at 39Ω. I used two in series for 78Ω and that worked too. I don't know what the upper limit on resistor size is, but given the 78 worked I figure something lower than that should be OK.
Edit: I tried to test what voltage really gets applied to this valve, but I was unsuccessful. The valve is probably only opened (turned on) when the bike is at speed and the engine is warm. So I decided to try a larger resistor. I found some 51Ω 6W resistors. I again tested two resistors in series, and the engine light stayed off, so a single resistor at 51Ω should work fine. If 14V is applied to the 51Ω resistor, that comes to 3.8W, which should be OK with the 6W resistor rating.
Then I searched eBay for a cheap evap valve that looked to have the same connector. I found this thing:
It ended up not quite fitting the the stock connector on the bike: the keys were correct but it wouldn't quite latch. It was easy to trim the latching point a bit so that it fit.
I cut apart the valve to remove the connector and used a dremel and some files to expose the contacts:
I also noted this connector didn't quite latch onto the connector on the bike. I cut back this latching stud just a bit so it would latch:
Here I have covered the leads of the resistor with a bit of heat shrink and positioned them on the connector. I used a clamp to hold it all together for soldering:
Soldering completed:
I have now coated the resistor in epoxy and it is currently drying.
Valve A83-600 for Nissan Purge Volume Control Solenoid VSV FDCC100 0B0 | eBay
P/N FDCC100. NISSAN 350Z (2003 - 2004). NISSAN ALTIMA (1998 - 2002). NISSAN FRONTIER (1998 - 2000). NISSAN MAXIMA (1999 - 2002). NISSAN MURANO (2003 - 2005). NISSAN PATHFINDER (1998 - 2003). NISSAN QUEST 1999.
www.ebay.com
