Adjusting gear lever and foot brake
Oli
Switzerland
Hi guys
Has anyone any experience with adjusting the gear lever? The angle is too steep for me. And does anybody know if you can adjust the foot break. There it's even worse for me.
Cheers Oliver
The brake doesnt really adjust up and down... maybe a little if you fool with the mechanical stop, but its not really an adjuster.
The gear shifter does adjust, and you should adjust it to fit your boots, which will help with more positive shifts.
Pretty normal on the shifter adjustment, loosen the lock nuts and turn the shaft to adjust. Then re-tighten the lock nuts. It is also possible to move the position of the arm on the shift shaft, but that isnt normallly necessary.
Reactions: Oli
Thank you for the answer.
Its a pitty that I can't adjust the break. Maybe I have to change my sitting position. Because i cant rest my foot comfortably on the foot rest and the break. The angle is too steep.
But thx for the answer!
Exactly.
This i
Exactly.
This is why I find the "flat soled" boots are good.
Can you can put the ball of your foot on the peg normally, and then for braking slide the foot forward and grab the brake with your toes.
If you rest your foot above the brake while riding you will scrape your foot on the ground in the turns.
Here, check out what Mike has to say:
Reactions: Oli
I can't imagine the brake pedal not being adjustable?
If you take out the pin (red arrow)
Rotate the clevis to adjust it outward or inward, and do up the hex lock nut (blue arrow) looks like inward will lower the lever, and outward will raise it.
That's what I'd try anyway.
Exactly.
This i
Exactly.
so maybe my problem is not only the break pedal but also that the peg is not fitting for me. when I place the ball of my foot on the peg like you tell my the angel of my leg is quite uncomfortable. I have to try it later again. now its raining so I cant go for a test ride haha
I'm a bit afraid to change anything on the bike that isn't "normally" adjustable. I'm a new rider and I wouldn't know if it doesn't work in the end how it should haha. So you mean turning clockwise will raise it and counter clockwise will lower it? Do I have to loosen the hex lock nut first before trying to adjust right?
Cheers
Yes, you are right, the amount that it is adjustable, myself and others have found that on atleast our 2019 the stock position doesnt allow for any further down, only further up.
so that means for me adjusting the break lever by myself further down is not possible. Maybe a garage can?
This does only affect the free travel which I need to have right? I can't adjust really the height with adjusting there?
On mine, I could potentially get a few mm out of it by reducing the play.
If you go to far you are then not fully extending the cylendar as you let off the brake before the stop screw touches.
As Nampus mentions, you can try to adjust by by rotating the clevis.
On my bike and some others I heard from with pre-2020 model there is normally nothing to adjust in that direction as it was already at the one end of the adjustment from the factory... maybe with yours (2020+ model?) they had a different person on a different day and there is room to go both ways.
If you have tools and skills, then you can try it.
