ABS warning and Locking hand brake Lever
Alx_Blanco
Querétaro, México
Hi Guys, When start riding the 401 (2019) ABS warning lights up, and turn off after a while but it locks the hand brake lever. Its almost impossible to pulled it down its completely lock. Thats a very risky situation. The rear brake works fine but its not my first option (70/30 rule). Any of you Guys have had such a problem? thanx in advance
SOLVED
The front abs- speed sensor was causing the whole thing. I changed the rear sensor to the front and viceversa, and imnmediatly show "can bus ABS failure".
I guess some manufacturers weighten rear brake over front brake for ABS function. So as soon as I push the rear brake down this error message pops up.
I get the sensor changed and 0 problems.
