801 decals
Tom
Germany
As I haven't found any proper templates to cut some decals, I recreated the "Svartpilen" lettering and the "801" number from some Kiska design boards; and also recreated the "Vitpilen" lettering.
I have made some pdf-files that can be scaled to any size.
Edit: you can now download the files: post #11
Got inspired by Tom's great work.
Took the opportunity to sketch the other (most) Kiska design elements.
Other compositions are mostly re-iterations using these elements.
Far from perfect, mostly due to the crappy resolution of the original file I could find, but PDF available if you want.
Hello,
I've recently traded my Vitpilen 701 for an 801. Saw that we can buy unfinished tank panels OEM for the 801, so I've done that. I'll take the originals off and keep them as new. I've had the new panels painted in a satin black. I'd like to put some decals on them, the same 801 decals in matt white as are on the standard silver tank. Is there any chance someone on here could supply them? If possible I'd also like two small 'Vitpilen' decals of the same size as stock, and the 'for pioneers' decal if I can. I appreciate these might be a custom job but as long as the price isn't extortionate I'll be okay with making it worth your while
I can't upload pdf-files, but if you'll send me a pm with an email address I can send you the files.
Hello,
Hi!
if you'll send me a mail address, I can send you the "801" and "Vitpilen" letterings as PDF-files.
They can be scaled to any size.
You'll just need to find the right size and then let a shop make some decals from vinyl in the color you want.
Hi!
Hi Tom, Im having a pair of tank panels vinyl wrapped for my Vit 801. You mentioned that you could help with the 801 decal design for me to take to a decal maker. If they are still available I'd really appreciate you providing it. Will pm you with my email address.
Hi Mark, I've sent you a mail with the files.
