2021 tail tidy available soon/ voltage spike
Jason jambard
Knoxville Tennessee
So man in the box "mnnthbx.com" happens to have their wearhouse 8 min from my house and also happens to need a 2021 vitpilen to get measurements for a new tail tidy kit. I wanted to share in case you was like me and couldn't find a tail tidy kit that would fit..they will be offering one I would say fairly soon.. I also wanted to see if anyone had any info on why my bike keeps throwing a voltage code. Ill be riding and out of know were the throttle quits working. Has happened 4 times and nearly got me killed switching lanes yesterday. Dealership was just clearing the code the 1st 2 times but now said they will contact husqvarna to find a solution. I litterally own the 1st vitpilen they ever sold so I'm not confident its gonna resolve it self soon. They also over filled my bike with oil at the 1st 624 mile service. Which seems to have the bike running really sluggish. But im more concerned ab the voltage spike's that keep happening. The only constant when it happens is hottest part of day and idling. Long idles seem to trigger it.. have yet to see a forum that mentions throttle loss or voltage problems.
Replaced the battery yet?
If it were my bike, I would replace the battery, clear the codes.
Then do a initialization (start the bike cold -less than 25°c water temp- in neutral and let it idle for 600 seconds without touching anything. Then after 600 seconds -10 min- turn the key off.)
Then all the stuff should be reset... the bike parameters should start from scratch and once you ride around and use open/closed loop in all the gears a time or two it should run like a champ.
But first, replace the battery, even if its new.
