The 2020 manual claims the rear spring is 180mm long.
And the rate is progressive from 100 - 150 N/mm (571 - 857 lb/in)
Since the diameter isn't stated, I roughly measured the spring on my rear shock.
It seems to have an 80-85mm OD (outside diameter) and the wire is about 12.2mm OD.
So that means the spring diameter to the wire center on both sides is approx 72mm.
And the ID (internal diameter) is about 60mm.
A bit of web searching revealed these single rate H&R springs for cars with an ID of 60mm and 180mm length:
Now the question is what rate to try. My rear shock is too stiff. So I certainly want less than 150 N/mm, I think.
But I'm not sure how to pick... any advice?
